Anoying interface problem
Postby cyrus_nk » Wed Mar 09, 2011 9:55 am
Hi guys!
I use QCad on Debian Linux and the only issue i have is that the QCad interface starts in the old Linux interface and even if i change the QT settings and restart QCad the same old ugly interface.
I have QT3 and QT4 installed used by QT Linguist, this should be the problem?!
Thank you very much!
Postby matbech » Sun Apr 03, 2011 1:18 am
Debian Qcad uses qt3. You can change qt3 global settings installing the package qt3-qtconfig and a qt3 config item should appear in your application menu...
