Offset
Offset
Postby matbech » Wed Jun 01, 2011 10:31 am
If I draw a spline and then explode it, is there any way to offset that path?
I tried with parallel lines, but it is a very long task!
matbech
Postby andrew » Wed Jun 01, 2011 10:37 am
Not with the QCAD Community Edition.
With QCAD Professional, combine the segments to a polyline and use the polyline equidistant tool.
Re: Offset
Postby dilasso » Mon Mar 31, 2014 9:32 am
Hi Andrew,
i tried to follow your steps. I had a spline, exploded it ( had to do it twice actually) and tried to combine the segements. But i got an error saying:"Element is no line or arc".
What did i do wrong?
dilasso
Re: Offset
Postby dilasso » Mon Mar 31, 2014 9:38 am
OK, found it out:
after the first "explode"-command the spline was already a polyline. It was then already possible to offset the line with the command equidistance.
dilasso
