Request - for Construction line tool
Postby Clive » Sun Aug 11, 2013 5:03 pm
Please may I request to the QCAD community a script Add-On for a new tool :wink:
My request is for a Construction line tool (infinite lines).
I constantly use temporary construction/reference lines when drawing in QCAD. Usually I set up a dedicated layer for this whereby I will choose a specific layer colour (usually Cyan) and on this layer I will draw all of my 'working' construction lines using the line tools, this means that I have to continually pick and choose the line tool I need and place/set the lengths I need all the time!
I would like to see a specific dedicated tool in QCAD for doing this instead.
I would imagine the 'Construction' line tool to have Infinite lines and fields for typing in the angle required.
Construction lines example.png (8.75 KiB) Viewed 3007 times
Many thanks and regards
Moderator / Drawing Help
Return to QCAD 3 ' Script Add-On & Plug-in challenge ' - Work in Progress
