Request - Closed contour area mill path.
Postby srl » Wed Oct 16, 2013 11:58 am
My dream script is to select a closed contour, enter a path spacing (tool width) and have a spiral path appear to the center. Only lines would be fine, any arcs around the outer could be finished manually. It would save me a lot of time on new designs.
The maths involved is a bit beyond me.
Stephen.
srl
Re: Request - Closed contour area mill path.
Postby srl » Sun Dec 22, 2013 8:01 am
Here is the example of what I wish. This all done manually.
This mill path uses my Cam config script with details in the layer names as you can see.
srl
srl
Postby srl » Wed Apr 30, 2014 7:24 am
Now done.
http://www.qcad.org/rsforum/viewtopic.php?f=74&t=2601&start=15#p9702
It took a bit of problem solving.
I only have a little more work to do with the ramp off.
srl
srl
Return to QCAD 3 ' Script Add-On & Plug-in challenge ' - Work in Progress
