QCAD 3 Final for more Linux Distributions
Announcements of new QCAD Versions, Updates, new Documentation, ... Please refer also to the RibbonSoft web site.
Postby andrew » Fri Jul 27, 2012 1:10 pm
I've uploaded alternative packages for (X)Ubuntu 10.04, Debian 6 and some other Linux distributions which are not compatible with the regular QCAD packages.
Please check your download area for the packages called 'Linux (Alternative)' if you are using one of these distributions or the current packages show errors such as:
/usr/lib/libstdc++.so.6: version `GLIBCXX_3.4.14' not found
Or:
I/O error : No such file or directory
/usr/share/mime/inode/directory.xml:1: parser error : Extra content at the end of the document
Return to Announcements
