QCad 2.1.2.8 released
Announcements of new QCAD Versions, Updates, new Documentation, ... Please refer also to the RibbonSoft web site.
Postby andrew » Mon Apr 02, 2007 10:51 pm
QCad 2.1.2.8 has been released today.
Probably the most valuable addition of this release is the property editor that can be used to change the properties of a single entity or many selected entities at once. This way is is possible to change the text height of a number of text entities or change the radius of a couple of circles in one step.
Another handy feature is that you can now display the key codes for each command in the menu. Almost every command in QCad has now a two letter key code. This will increase your productivity quite significantly.
Finally, the new possibility to rotate, scale or flip entities while they are pasted from the clipboard might be worth mentioning. Try this the next time you need to create a rotated, scaled or flipped copy of your selection.
Other improvements have been made in the following areas: drag and drop or reference points, support for international texts with "standard" font, auto snap feature.
Return to Announcements
