M3 codes - seeing the cut order.
Use this forum to ask questions about how to do things in CAM Expert.
Postby ADucci » Mon Oct 08, 2007 2:55 pm
I can design a shape in Cam Expert, then export it to NC file, the only problem is that i need to insert lead ins, and cut orders, as well well cut direction before it generated the G-code. also there are no M3 commands that acutally perform the cut, in the output.
how do you do this?
Postby michael » Fri Nov 02, 2007 12:56 pm
Maybe width the "machine generator".
Adjust it to your machine.
Do you CAD? - I do QCad.
Return to “CAM Expert 'How Do I' Questions”
