Use this forum to ask questions about how to do things in CAM Expert.
Postby carlhelquist » Wed Sep 16, 2009 10:06 pm
I am trying to have a tool change at the start of each layer only if a layer parameter is set to yes.
Here are the lines I added:
in [LayerParameter]
LayerParameter fixed $T Tool_Change? Yes No
LayerParameter free $t 1 2 3 4 5 6 7 8
in [Code]
{<NewLine>t$t m6
<NewLine>g43 h$t}
{<if:$l=Yes><UpdateLayer><NewLine><NewLine>(Layer: $_)
My problem seems to be that once the <if:> statement runs, the variable is stuck on the value it had when first checked. All subsequent layers are stuck with that value. Other layer parameters that I have added seem to change by layer as long as I don't use them in an <if:>.
Any ideas on what I am missing?
Carl Helquist
using camexpert- on Ubuntu 8.04
Return to “CAM Expert 'How Do I' Questions”
