CAM expert crash
If you are having problems with CAM Expert, post here. Please report bugs here.
BlueCabbie
CAM expert crash
Postby BlueCabbie » Sat Apr 17, 2010 4:21 am
Is there a newer version?
Process:         CAMExpert [924]
Path:            /Applications/_applications/CADCAM/camexpert-2.0.5.0-1-prof.macosx.ppc/CAMExpert.app/Contents/MacOS/CAMExpert
Identifier:      CAMExpert
Version:         ??? (???)
Code Type:       PPC (Translated)
Parent Process:  launchd [136]
Date/Time:       2010-04-16 22:17:38.118 -0500
OS Version:      Mac OS X 10.6.3 (10D573)
Report Version:  6
Interval Since Last Report:          444085 sec
Crashes Since Last Report:           5
Per-App Crashes Since Last Report:   1
Anonymous UUID:                      3C128653-738C-4D39-A30A-6DCDFCDBFC57
Exception Type:  EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_PROTECTION_FAILURE at 0x00000000bf7ffff0
Crashed Thread:  0  Dispatch queue: com.apple.main-thread
Thread 0 Crashed:  Dispatch queue: com.apple.main-thread
0   ???                              0x7f8f4163 0 + 2140094819
Thread 1:
0   libSystem.B.dylib                0x801402fa mach_msg_trap + 10
1   libSystem.B.dylib                0x80140a67 mach_msg + 68
2   CAMExpert                        0xb819440f CallPPCFunctionAtAddressInt + 206231
3   libSystem.B.dylib                0x8016da19 _pthread_start + 345
4   libSystem.B.dylib                0x8016d89e thread_start + 34
Thread 2:
0   CAMExpert                        0xb815acc0 spin_lock_wrapper + 90152
1   CAMExpert                        0xb8179c5b CallPPCFunctionAtAddressInt + 97763
2   CAMExpert                        0xb80c6b13 0xb8000000 + 813843
3   CAMExpert                        0xb80c0037 0xb8000000 + 786487
4   CAMExpert                        0xb80dd8e8 0xb8000000 + 907496
5   CAMExpert                        0xb8145397 spin_lock_wrapper + 1791
6   CAMExpert                        0xb801ceb7 0xb8000000 + 118455
Thread 3:
0   CAMExpert                        0xb815a8ff spin_lock_wrapper + 89191
1   CAMExpert                        0xb8176e5d CallPPCFunctionAtAddressInt + 85989
5   CAMExpert                        0xb8145c1d spin_lock_wrapper + 3973
Thread 0 crashed with X86 Thread State (32-bit):
  eax: 0xbf7ffff0  ebx: 0x1ab670c0  ecx: 0xbf80110c  edx: 0x7f88b0f4
  edi: 0x00000004  esi: 0xa0361338  ebp: 0x8a028d80  esp: 0xb7fffacc
   ss: 0x0000001f  efl: 0x00010286  eip: 0x7f8f4163   cs: 0x00000017
   ds: 0x0000001f   es: 0x0000001f   fs: 0x00000000   gs: 0x00000037
  cr2: 0xbf7ffff0
Binary Images:
0x80000000 - 0x8005bff7  com.apple.framework.IOKit 2.0 (???) <69E4FE93-376C-565E-650F-04FAD213AA24> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x8007a000 - 0x800e4fe7  libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
0x8013f000 - 0x802e4feb  libSystem.B.dylib 125.0.1 (compatibility 1.0.0) <06A5336A-A6F6-4E62-F55F-4909A64631C2> /usr/lib/libSystem.B.dylib
0x80364000 - 0x804ddffb  com.apple.CoreFoundation 6.6.1 (550.19) <1E97FB1E-9E42-B8EB-E463-5C75315FDA31> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x805d5000 - 0x805e3fe7  libz.1.dylib 1.2.3 (compatibility 1.0.0) <82B2C254-6F8D-7BEA-4C18-038E90CAE19B> /usr/lib/libz.1.dylib
0x805e8000 - 0x805f4ff7  libkxld.dylib ??? (???) <13F26BB6-C2F7-9D74-933E-09AD8B509ECD> /usr/lib/system/libkxld.dylib
0x805f8000 - 0x8063eff7  libauto.dylib ??? (???) <85670A64-3B67-8162-D441-D8E0BE15CA94> /usr/lib/libauto.dylib
0x8064b000 - 0x807cdfe7  libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <96A45E03-2B29-83EB-0FC6-2C932E398722> /usr/lib/libicucore.A.dylib
0x8082f000 - 0x808dcfe7  libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <DF8E4CFA-3719-3415-0BF1-E8C5E561C3B1> /usr/lib/libobjc.A.dylib
0x808f0000 - 0x808f3fe7  libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
0x8fe00000 - 0x8fe4162b  dyld 132.1 (???) <211AF0DD-42D9-79C8-BB6A-1F4BEEF4B4AB> /usr/lib/dyld
0xb8000000 - 0xb81defff +CAMExpert ??? (???) <C6CB6BA8-8BA2-8F0A-4A49-912B00D2FF10> /Applications/_applications/CADCAM/camexpert-2.0.5.0-1-prof.macosx.ppc/CAMExpert.app/Contents/MacOS/CAMExpert
0xffff0000 - 0xffff1fff  libSystem.B.dylib ??? (???) <06A5336A-A6F6-4E62-F55F-4909A64631C2> /usr/lib/libSystem.B.dylib
Translated Code Information:
objc[924]: garbage collection is ON
Rosetta Version:  22.26
Args:     /Applications/_applications/CADCAM/camexpert-2.0.5.0-1-prof.macosx.ppc/CAMExpert.app/Contents/MacOS/CAMExpert -psn_0_495737
Exception: EXC_BAD_ACCESS (0x0001)
Thread 0: (0xb019ed74, 0xb815a8ff)
0x966d7038: /usr/lib/libSystem.B.dylib : __dispatch_semaphore_wait_slow + 248
0x966d5724: /usr/lib/libSystem.B.dylib : __dispatch_worker_thread + 116
0x965f57e8: /usr/lib/libSystem.B.dylib : __pthread_body + 40
0x00000000: /Applications/_applications/CADCAM/camexpert-2.0.5.0-1-prof.macosx.ppc/CAMExpert.app/Contents/MacOS/CAMExpert :  + 0
PPC Thread State
srr0: 0x00000000   srr1: 0x00000000                   vrsave: 0x00000000
cr:  0xXXXXXXXX      xer: 0x20000000       lr: 0x966d7050      ctr: 0x96555140
r00: 0xffffffda    r01: 0xf0182dc0    r02: 0x00000000    r03: 0x00002903
r04: 0x00000040    r05: 0x3b9a5e74    r06: 0x00000020    r07: 0x00000000
r08: 0x3b9a5e74    r09: 0x00000000    r10: 0x3b9a5e74    r11: 0xa0b0b664
r12: 0x96555140    r13: 0x00000000    r14: 0x00000000    r15: 0x00000000
r16: 0x00000000    r17: 0x00000000    r18: 0x00000000    r19: 0x00000000
r20: 0x00000000    r21: 0xa0b117ac    r22: 0xa0b117a0    r23: 0xa0b117a8
r24: 0x00000e09    r25: 0x750e68a5    r26: 0xa0b114ec    r27: 0x00000040
r28: 0x0000000f    r29: 0x224cde74    r30: 0xa0b11780    r31: 0x966d6f48
Thread 1: (0xb011cd38, 0xb815acc0)
0x966d5a4c: /usr/lib/libSystem.B.dylib : __dispatch_mgr_invoke + 228
0x966d5430: /usr/lib/libSystem.B.dylib : __dispatch_queue_invoke + 308
0x966d55c0: /usr/lib/libSystem.B.dylib : __dispatch_worker_thread2 + 372
0x966d56fc: /usr/lib/libSystem.B.dylib : __dispatch_worker_thread + 76
PPC Thread State
cr:  0xXXXXXXXX      xer: 0x20000000       lr: 0x966d5a14      ctr: 0x96598cec
r00: 0x0000016b    r01: 0xf0101bb0    r02: 0x00000000    r03: 0x00000004
r04: 0x00000000    r05: 0x00000000    r06: 0xf0101d0c    r07: 0x00000001
r08: 0xf0101d28    r09: 0x00000000    r10: 0x0000003e    r11: 0xa0b0a520
r12: 0x96598cec    r13: 0x10624dd3    r14: 0x96724b24    r15: 0xf0101c0c
r16: 0xf0101c8c    r17: 0xa0b25970    r18: 0xf0101d28    r19: 0xa0b1f500
r20: 0xa0b20500    r21: 0xf0101d0c    r22: 0xa0b1f480    r23: 0xa0b1f400
r24: 0xa0b25970    r25: 0x00000000    r26: 0xa0b1160c    r27: 0x00000000
r28: 0xa0b115e4    r29: 0xa0b1131c    r30: 0xf0101d28    r31: 0x966d5970
Thread 2: Crashed (0xb7fffacc, 0x7f8f4163)
0x90983ce4: /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation : _CFBasicHashFindBucket + 116
0x92571fec: /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox : _SetEventParameter + 304
0x00338c78: /Applications/_applications/CADCAM/camexpert-2.0.5.0-1-prof.macosx.ppc/CAMExpert.app/Contents/MacOS/CAMExpert : __mh_execute_header + 3374200
0x9255c81c: /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox : DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1524
0x9255d1d8: /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox : SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 456
0x9255d4b8: /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox : _SendEventToEventTargetWithOptions + 72
0x92414840: /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox : Accessible::SendEvent(OpaqueEventRef*, bool) const + 108
0x924163a4: /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox : Accessible::GetDeepFocus(__AXUIElement const**) + 76
0x9241642c: /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox : Accessible::GetDeepFocus(__AXUIElement const**) + 212
PPC Thread State
cr:  0xXXXXXXXX      xer: 0x00000000       lr: 0x92571e24      ctr: 0x96556860
r00: 0x92571e24    r01: 0xbf800ff0    r02: 0x00000020    r03: 0xbf80110c
r04: 0x1ab670ce    r05: 0x00000004    r06: 0x00000001    r07: 0x00000004
r08: 0xbf80110c    r09: 0x61636365    r10: 0x00000001    r11: 0xa0361338
r12: 0x96556860    r13: 0x00000000    r14: 0x00000000    r15: 0x00000000
r16: 0xbffff45c    r17: 0x00000000    r18: 0xa0b126b0    r19: 0xbfffa904
r20: 0xbfffa87c    r21: 0xbfffa8ec    r22: 0xbfffa900    r23: 0x00000000
r24: 0xbf80110c    r25: 0x63667479    r26: 0x00000001    r27: 0x00000004
r28: 0x6163686c    r29: 0x1ab67020    r30: 0x1ab670c0    r31: 0x00338b74
Model: MacBookPro5,2, BootROM MBP52.008E.B05, 2 processors, Intel Core 2 Duo, 2.93 GHz, 4 GB, SMC 1.42f4
Graphics: NVIDIA GeForce 9600M GT, NVIDIA GeForce 9600M GT, PCIe, 512 MB
Graphics: NVIDIA GeForce 9400M, NVIDIA GeForce 9400M, PCI, 256 MB
Memory Module: global_name
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8D), Broadcom BCM43xx 1.0 (5.10.91.27)
Bluetooth: Version 2.3.1f4, 2 service, 19 devices, 1 incoming serial ports
Network Service: AirPort, AirPort, en1
Serial ATA Device: Hitachi HTS723232L9SA62, 298.09 GB
Serial ATA Device: MATSHITADVD-R   UJ-868
USB Device: Built-in iSight, 0x05ac  (Apple Inc.), 0x8507, 0x24400000
USB Device: BRCM2046 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0x06100000
USB Device: Bluetooth USB Host Controller, 0x05ac  (Apple Inc.), 0x8217, 0x06110000
USB Device: Apple Internal Keyboard / Trackpad, 0x05ac  (Apple Inc.), 0x0236, 0x04600000
USB Device: IR Receiver, 0x05ac  (Apple Inc.), 0x8242, 0x04500000
Return to “CAM Expert Troubleshooting and Problems”
