Scripting the AC
Scripting the AC
Postby rick971 » Fri Jul 23, 2010 5:01 am
I design PCBs that interface DUTs to semiconductor test equipment. Most of the time my customers provides a .dxf file of the PCB outline that also contains the landing pads for the interposer.
In the past I have used AC to locate the pad locations and angles. Is there a scripting method I can use to accomplish the same thing in QCAD?
Users browsing this forum: Bing [Bot] and 3 guests
