Which version after an order?
Postby tukuyomi » Mon Aug 09, 2010 6:29 pm
Hello everbody.
With the upcoming release of qcad 3 (and the possible free upgrade :D), I plan to buy qcad 2.2.1 really soon.
Still, I have two questions before buying:
- When I order my download location, which version of Qcad can I download? Or more precisely, can I download Windows AND Linux versions with only one license? Or have I to pay one for every version I want?
- Do you plan to add a function/menu entry that can "Remove duplicate elements" in Qcad 3 (say remove 1 of 2 lines that have the same start and end points)
Thank you for reading.
tukuyomi
Re: Which version after an order?
Postby andrew » Mon Aug 09, 2010 8:13 pm
tukuyomi wrote:can I download Windows AND Linux versions with only one license?
Yes, you can download QCAD for all supported platforms. Licenses are user based, so you may install and use QCAD on any number of computers / operating systems if you are the only user.
Postby andrew » Mon Aug 09, 2010 8:14 pm
tukuyomi wrote:Do you plan to add a function/menu entry that can "Remove duplicate elements" in Qcad 3 (say remove 1 of 2 lines that have the same start and end points)
Possibly. In any case, it will be really easy to add new tools like this as scripts in QCAD 3.
Postby tukuyomi » Mon Aug 09, 2010 8:59 pm
Thank you for those precisions andrew!
-> Going to download my professional version ^^
tukuyomi
Postby golia » Mon Aug 09, 2010 10:05 pm
I can not wait to see the version QCAD3.
Of what?
golia
Return to Pre-sales Questions
