System Hardware Requirements For Running on Windows XP Pro
argranquist
Postby argranquist » Fri Apr 27, 2012 3:47 pm
What are the System Hardware Requirements (minimum & recommended) for running QCAD on Windows XP Pro? Minimum & recommended?
Re: System Hardware Requirements For Running on Windows XP P
Postby andrew » Fri Apr 27, 2012 4:12 pm
Thanks for your interest in QCAD.
For running QCAD under Windows XP:
- About 150 to 200MB of free disk space.
Minimum:
- 500MHz or faster 32-bit (x86) or 64-bit (x64) processor
- 512MB RAM
Recommended:
- 1GHz or faster 32-bit (x86) or 64-bit (x64) processor
- 2 gigabyte (GB) RAM
Please note that the actual requirements depend on the complexity of the drawings you are viewing and editing as well as on other factors such as if you are planning to run many complex applications in parallel.
argranquist
Postby argranquist » Fri Apr 27, 2012 4:19 pm
Thanks for the quick response!
