Buying QCAD 2 instead of version 3
Postby Arkem » Tue Aug 21, 2012 2:50 pm
I am using the community version very often and I am starting to think it worth for me to buy a full recent version. I tried the demos for that purpose, but discovered everything is terribly slow, even without any drawing loaded in version 3, while the version 2 run like a charm. I have no idea which configuration is needed for the version 3 to run correctly, but it is clearely not for any of my computers. Is it still possible to buy the version 2 instead in such case?
Arkem
Re: Buying QCAD 2 instead of version 3
Postby andrew » Tue Aug 21, 2012 6:14 pm
Thanks for your interest in QCAD Professional.
Yes, after your purchase you can access both versions (QCAD 2.2 and QCAD 3.0) immediately.
Postby Arkem » Wed Aug 22, 2012 6:11 am
Thank you very much for your quick response :)
Arkem
Return to Pre-sales Questions
cron
