Pro-Version as ZIP
Pro-Version as ZIP
Postby henry » Tue Aug 27, 2013 10:48 am
Hello.
Search on the topic gives no results even i vary the question.
So, can pls. someone tell me of the pro version is also available as zip file, or is insatllation
of the buyed version generally required?
I would use qcad on a usb stick.
tia, Henry
henry
Re: Pro-Version as ZIP
Postby andrew » Tue Aug 27, 2013 11:02 am
Thanks for your interest in QCAD Pro.
Yes, QCAD Pro for Windows can also be installed from a ZIP file. In this case, the Windows Registry will not be modified which means that DXF and DWG files will not be linked to QCAD.
User specific configuration settings are always stored in the user's home directory in file QCAD.ini.
Please let me know if you have any further inquiries.
Andrew
Postby henry » Tue Aug 27, 2013 12:22 pm
Hello Andrew,
thx, for giving the answer i hoped on :)
Good news, so i will be in the club.
henry
Return to Pre-sales Questions
