QCAD keyboard buttons - command line
Good evening everyone,
I'm Italian.
I have a problem with QCAD: when I enter the commands in the appropriate line the unassigned keys, especially the special ones.
I ask if anyone has ever had a similarity problem and if they have solved it.
I specify that the language settings are correct and I have this problem only with QCAD.
Thank you
I'm Italian.
Thank you
Re: QCAD keyboard buttons - command line
Thanks for your post.
Please always indicate your operating system and QCAD version. Please read also the forum rules at the top (red).
I have ubuntu 21.10,
In the command line I pressed "@" and the screen displays ";"
thank you
thank you
- screenshot command line
- qcad screeshot.png (116.9 KiB) Viewed 12651 times
You very likely need to install a different package:
QCAD Professional 3.27.1 for Linux Qt 5.14 64bit (Installer)
File: qcad-3.27.1-pro-linux-qt5.14-x86_64.run
i installed the latest version, but the problem remained,
other ideas
other ideas
Please indicate what exact package you have downloaded (exact file name). Thanks.
I have installed this version: qcad-3.27.1-trial-linux-x86_64.run
This version is bad?
I've moved your question to the pre-sales forum as you are not using the full version of QCAD Professional.
On the download page, scroll down to "All Downloads", then
Linux 64bit Qt 5.14 (Wayland support) Installer
Thankyou verymuch!!
but i have another problem now.... i open a new topic...
