Finding a percentage of an area within a surrounding area
Postby Mark Cooper » Wed Aug 26, 2009 9:56 pm
I have a simple need. I take an aerial photo of a roof, I trace a vector path around the roof edges as a closed path in Illustrator. I also have closed paths of irregular shapes within the outline of the roof. If I export a DXF file from Illustrator and open it in QCAD, is it possible to calculate the percentage of the roof that had the irregular shapes? This is the only purpose I have for making a decision to purchase QCAD. Thanks.
As president of Quick-Draw Creative Group, I specialize in graphic design and aerial infrared photography for engineering companies and building managers.
Mark Cooper
Postby andrew » Fri Aug 28, 2009 7:56 am
No, there is no tool for this.
Return to Pre-sales Questions
