Arrays
sjam986
Arrays
Post by sjam986 » Sat Aug 20, 2022 4:18 am
Is there a way to produce linear and polar arrays in QCAD?
Re: Arrays
Post by Husky » Sat Aug 20, 2022 4:45 am
Yes, there are a few ways to do that. To be sure that your case is covert please download the free of charge QCAD trial version and test it by yourself or post an example of your application and we take it from there ... :wink:
https://www.qcad.org/en/qcad-downloads-trial
Re: Arrays
Post by CVH » Sat Aug 20, 2022 5:23 am
Not that they are one single item ...
A linear array could be copy/paste n times for example.
One can also rotate copies n times and also with a secondary angle
Blocks can be placed in n rows and m columns and that at an angle.
