DXF AutoCAD 2002 (15.2) limits
Please use this forum to post feedback and suggestions related to dxflib.
Postby wit » Tue Nov 29, 2011 10:50 pm
Is there any documentation specifying the limits of the DXF AutoCAD 2002 (15.2) file format:
- max number of points, lines, splines...and so forth. (per layer ?)
- max number of layers.
- max file size
Many thanks for your help.
wit
Postby andrew » Wed Nov 30, 2011 12:10 am
I'm unaware of any relevant limit that would be enforced by the file format.
Theoretical limits enforced by object handles and data types exist of course but are exorbitant.
File size might be restricted by some older Windows file systems (FAT32) to about 4GB.
A DXF reference with general documentation about data types and fields is available from Autodesk: http://www.google.com/?q=dxf+reference
Postby wit » Wed Nov 30, 2011 9:30 am
Thanks for your quick answer.
So I'm investigating the upload process.
FYI, I'm using DXF format to upload point clouds, I need to investigate were the blocking limits are coming from.
wit
Return to dxflib Suggestions and Feedback
