What Versions of AutoCAD does dxflib work with?
Please use this forum to post feedback and suggestions related to dxflib.
Postby pricecreations » Thu Aug 02, 2007 2:40 pm
Is dxflib compatible with AutoCAD 2004?
pricecreations
Postby andrew » Fri Aug 03, 2007 9:01 am
When reading a DXF file, dxflib handles all entities that are supported by dxflib regardless of the DXF version of the file.
When writing, you can specify the version to write, e.g.:
DL_WriterA* dw = dxf.out("myfile.dxf", DL_Codes::AC1015);
dxflib supports the Autocad R12 and Autocad 2000 DXF specifications.
Postby xelecara » Thu Jun 23, 2011 11:11 am
Question about Pro Engineer CAD software? My professional edition of Pro-E won't open files that were created in the student edition of the software. I have several CAD drawings that I created at school and now I can't use them at home. Is there a workaround/hack to this BS from Dassault?
xelecara
Postby andrew » Thu Jun 23, 2011 11:28 am
xelecara: Not sure I understand. Where the files created with dxflib or QCAD at all?
Return to dxflib Suggestions and Feedback
cron
