Re-entrant polygons/embedded polygon
Posted: Mon Mar 22, 2010 7:07 pm
We are evaluating DXFLIB. DXF files with embedded polygons seems to show up just fine in QCAD.
However, there seems to be an issue handling such polygons when using DXFLIB.
See the attached picture. The first is in QCAD where the polygons are being treated OK, the second is using DXLIB. As you can see there is a clear difference. Is there some functionality that I am missing in DXFLIB?
Thanks,
-S
Thanks,
-S
