Block insert
Use this forum to ask questions about how to do things in dxflib.
Block insert
Postby sekigawa » Sat Sep 25, 2010 7:41 am
I want to join two existing DXF files (say, "no1.dxf" and "no2.dxf")
to create a new one (say, "no3.dxf") by "block insertion."
In the simplest case, only one instance of "no1.dxf" and "no2.dxf" are
inserted into "no3.dxf" without rotation, magnification, and transformation.
Then, the command line would look like
$ joindxf -i no1.dxf -i no2.dxf -o no3.dxf
How can I achieve this using "dxflib" ?
Return to “dxflib 'How Do I' Questions”
