Writing dimensions in a dxf file using dxflib
Posted: Thu Nov 03, 2011 8:15 pm
I don't succeed to write dimensions in a dxf file that can be imported in AutoCAD 2010. I have written a dimension style with writeDimStyle() and a linear dimension entity with writeDimLinear().
AutoCAD imports the file without message but the dimension is not visible. DXFOUT in AutoCAD writes the dimension again in an output file.
When I replace part of a dxf file that contains a dimension entity drawn in AutoCAD by the part out of my DXF file it can be imported on the condition that the entity refers to a block that defines the look.
Is it possible to write dimension entities on an easy way using the library functions?
