How do I write DXF text to stdout?
Use this forum to ask questions about how to do things in dxflib.
chainichek
Postby chainichek » Sat Mar 24, 2012 5:24 pm
I use DL_WriterA to write DXF text to some.dxf file. Is there any way to redirect DXF text to stdout?
Re: How do I write DXF text to stdout?
Postby andrew » Thu Mar 29, 2012 11:04 pm
Not directly from dxflib. You'd have to generate a temporary file and then stream it to stdout.
chainichek
Postby chainichek » Fri Mar 30, 2012 8:32 am
I use 'tmpnam' to generate temporary file name although the manual page on 'tmpnam' does not recommend to use this function:
#man 3 tmpnam
BUGS
Never use this function. Use mkstemp(3) or tmpfile(3) instead.
Could you recommend more coorect way to generate temporary file for writing DXF data?
Postby andrew » Mon Apr 02, 2012 2:41 pm
The man page seems to suggest 'Use mkstemp(3) or tmpfile(3) instead.'
I haven't used these lately, but according to their man pages they might provide what you are looking for.
chainichek
Postby chainichek » Mon Apr 02, 2012 3:19 pm
DL_WriterA requires file name as parameter while these (safe) functions return file descriptor or stream -- not file name.
Postby andrew » Tue Apr 03, 2012 10:54 am
You are right. dxflib would have to be adjusted to work with those functions.
A possible solution might be to create a temporary directory instead of a file using mkdtemp.
You could then create file(s) inside that directory with any fixed or dynamic name(s).
Return to “dxflib 'How Do I' Questions”
