dxf->writeHatch, but how ?
Use this forum to ask questions about how to do things in dxflib.
Postby bonsalty » Wed Jun 10, 2009 10:12 am
I havent found how to write a hatch into dxf
We have:
void DL_Dxf::writeHatch1 ( DL_WriterA & dw,
const DL_HatchData & data,
const DL_Attributes & attrib
where DL_HatchData (int hNumLoops, bool hSolid, double hScale, double hAngle, const string &hPattern)
First question: what shoud hPattern be and whats this hNumLoops all about?
Second question:
If I call :
void DL_Dxf::writeHatchLoop1 ( DL_WriterA & dw,
const DL_HatchLoopData & data
should I call the writeHatchEdge functions after this or before the writeHatchLoop?
Third question,why must I call writeHatch2 and how to use it ????
An example would be nice,since its impossible to decode it from the ribbonsofts class reference. Thank you!
bonsalty
Postby andrew » Wed Jun 10, 2009 2:11 pm
works, but not everything...
Postby bonsalty » Wed Jun 10, 2009 7:27 pm
Thanks I managed to use it. I inserted a single loop with 3 edges(a triangle :) ) and succeded to make a triangle with hatch.
But pattern name is still a mistery.
I tried "EARTH", "ANSI31",... default pattern names,but nothing happens. However I can see that names in autocad when I click on my hatchobject, but it doesnt change the hatch style?!
I tried rotate and scale property too,they doesnt work either. Its always a 45 degree hatch.The solid property works fine.
bonsalty
Re: dxf->writeHatch, but how ?
Postby wolfhergang » Thu Nov 07, 2013 11:14 pm
Im having some troubles in writing a solid arc hatch, i wrote a single hatch, with a single loop with a single edge all of em with the same attributes and it just doesnt work, any advice?
wolfhergang
Postby wolfhergang » Thu Nov 14, 2013 12:56 am
Anyone?
wolfhergang
Postby andrew » Thu Nov 14, 2013 2:01 pm
wolfhergang: Can you post your code or the exact example data?
I don't see how a hatch with one loop which contains one arc can form a closed, hatchable contour (unless the arc is in fact a full circle?).
Postby wolfhergang » Fri Nov 15, 2013 12:17 am
My code is this:
DxfExporter exportador("testingWriting.dxf");
exportador.addEntity(new DxfCircle(0,0,0,100,DL_Attributes()));
DL_Attributes generalAttrib = DL_Attributes("0",2,16776960, -1, "BYLAYER");
exportador.addEntity((new DxfHatch(1,true,1,0,"SOLID",generalAttrib)));
exportador.addEntity(new DxfHatchLoop(1,generalAttrib));
exportador.addEntity(new DxfHatchEdge(0,0,100,0,6.75,true,generalAttrib));
if(exportador.writeToDxfFile()){
std::cout<<"File wrote correctly"<<std::endl;
}else{
std::cout<<"Error at writing"<<std::endl;
in my implementation you "add" the entities to a container then you write the container to the file.
the entity constructors are basically the same as the DL_Entity ones, but mine store the attributes, thats it.
the arc is supposed to be a full circle from 0 to 6.74 degrees but it doesnt render.
pd: sorry about my english, if something doesnt make sense let me know and ill try to explain myself.
wolfhergang
Postby wolfhergang » Fri Nov 15, 2013 12:22 am
Maybe im just confused about how im supposed to hatch things....
wolfhergang
Postby andrew » Fri Nov 15, 2013 2:13 pm
wolfhergang: this code does not look familiar to me. dxflib does not provide the classes named "DxfExporter", "DxfHatch", "DxfCircle", etc.
Here's a minimal but complete example that writes a DXF file with one hatch entity using dxflib 3.3.4:
#include "dl_dxf.h"
int main() {
DL_Dxf dxf;
DL_WriterA* dw = dxf.out("hatch.dxf", DL_Codes::AC1015);
// section header:
dxf.writeHeader(*dw);
dw->sectionEnd();
// section tables:
dw->sectionTables();
// VPORT:
dxf.writeVPort(*dw);
// LTYPE:
dw->tableLinetypes(1);
dxf.writeLinetype(*dw, DL_LinetypeData("CONTINUOUS", "Continuous", 0, 0, 0.0));
dxf.writeLinetype(*dw, DL_LinetypeData("BYLAYER", "", 0, 0, 0.0));
dxf.writeLinetype(*dw, DL_LinetypeData("BYBLOCK", "", 0, 0, 0.0));
dw->tableEnd();
// LAYER:
dw->tableLayers(1);
dxf.writeLayer(
*dw,
DL_LayerData("0", 0),
DL_Attributes("", 2, 0, 100, "CONTINUOUS")
dw->tableEnd();
// STYLE:
dw->tableStyle(1);
DL_StyleData style("Standard", 0, 0.0, 1.0, 0.0, 0, 2.5, "txt", "");
style.bold = false;
style.italic = false;
dxf.writeStyle(*dw, style);
dw->tableEnd();
// VIEW:
dxf.writeView(*dw);
// UCS:
dxf.writeUcs(*dw);
// APPID:
dw->tableAppid(1);
dxf.writeAppid(*dw, "ACAD");
dw->tableEnd();
// DIMSTYLE:
dxf.writeDimStyle(*dw, 2.5, 0.625, 0.625, 0.625, 2.5);
// BLOCK_RECORD:
dxf.writeBlockRecord(*dw);
dw->tableEnd();
dw->sectionEnd();
// BLOCK:
dw->sectionBlocks();
dxf.writeBlock(*dw, DL_BlockData("*Model_Space", 0, 0.0, 0.0, 0.0));
dxf.writeEndBlock(*dw, "*Model_Space");
dxf.writeBlock(*dw, DL_BlockData("*Paper_Space", 0, 0.0, 0.0, 0.0));
dxf.writeEndBlock(*dw, "*Paper_Space");
dxf.writeBlock(*dw, DL_BlockData("*Paper_Space0", 0, 0.0, 0.0, 0.0));
dxf.writeEndBlock(*dw, "*Paper_Space0");
dw->sectionEnd();
// ENTITIES:
dw->sectionEntities();
DL_Attributes attributes("0", 2, 0, -1, "BYLAYER");
// start hatch with one loop:
DL_HatchData data(1, false, 100.0, 0.0, "ESCHER", 0.0, 0.0);
dxf.writeHatch1(*dw, data, attributes);
// start loop:
DL_HatchLoopData lData(1);
dxf.writeHatchLoop1(*dw, lData);
// write edge:
DL_HatchEdgeData eData(
0.0,
0.0,
100.0,
0.0,
M_PI*2,
true
dxf.writeHatchEdge(*dw, eData);
// end loop:
dxf.writeHatchLoop2(*dw, lData);
// end hatch:
dxf.writeHatch2(*dw, data, attributes);
// end section ENTITIES:
dw->sectionEnd();
dxf.writeObjects(*dw, "MY_OBJECTS");
dxf.writeObjectsEnd(*dw);
dw->dxfEOF();
dw->close();
delete dw;
return 0;
Postby wolfhergang » Fri Nov 15, 2013 11:51 pm
My problem was that i was writing the hatch edge using degrees when im supposed to use radians.
DL_HatchEdgeData eData(0.0, 0.0, 100.0, 0.0, M_PI*2, true);
that single line solved my problem, than you very much Andrew.
wolfhergang
Return to dxflib 'How Do I' Questions
cron
