splines and fit points...
If you are having problems with dxflib, post here. Please report bugs here.
PerfiduS
Postby PerfiduS » Fri Apr 30, 2010 8:47 am
I'm trying the mighty dxflib in one of my project.
I've a problem with Spline defined with Fit Points, and without Control Points.. the parser does not read the FitPoints.
And then, if I read the Fit Points what formulation of Splines i must use to render the curve like AutoCAD?
Thanks, bye...
PerfiduS.
Return to “dxflib Troubleshooting and Problems”
