Ubuntu LTS 10.04 Compile Issue
Posted: Wed Aug 17, 2011 6:50 am
Using the build script I get this.
Building libdxf.a failed
The reason why I am compiling from source is :
The elipse function does not produce proper code for use in Autocad or dxf to gcode and is just a mess.
Help function .. does not work also.
gcc -v reports
errors
QTDIR is: /usr/share/qt4
QMAKESPEC is: /usr/share/qt4/mkspecs/linux-g++-32
Platform is Linux
Target is qcad_demo
QMAKE_OPT: CONFIG+=rs_demo
gcc -v reports
Using built-in specs.
Target: i486-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Ubuntu 4.4.3-4ubuntu5' --with-bugurl=file:///usr/share/doc/gcc-4.4/README.Bugs --enable-languages=c,c++,fortran,objc,obj-c++ --prefix=/usr --enable-shared --enable-multiarch --enable-linker-build-id --with-system-zlib --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --with-gxx-include-dir=/usr/include/c++/4.4 --program-suffix=-4.4 --enable-nls --enable-clocale=gnu --enable-libstdcxx-debug --enable-plugin --enable-objc-gc --enable-targets=all --disable-werror --with-arch-32=i486 --with-tune=generic --enable-checking=release --build=i486-linux-gnu --host=i486-linux-gnu --target=i486-linux-gnu
Thread model: posix
gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5)
errors
In file included from src/dl_writer_ascii.h:35,
from src/dl_writer_ascii.cpp:34:
src/dl_writer.h: In member function ‘void DL_Writer::entityAttributes(const DL_Attributes&) const’:
src/dl_writer.h:337: error: ‘strcasecmp’ was not declared in this scope
src/dl_writer_ascii.cpp: In member function ‘virtual void DL_WriterA::dxfReal(int, double) const’:
src/dl_writer_ascii.cpp:72: error: ‘strlen’ was not declared in this scope
src/dl_writer_ascii.cpp:81: error: ‘strlen’ was not declared in this scope
src/dl_writer_ascii.cpp: In static member function ‘static void DL_WriterA::strReplace(char*, char, char)’:
src/dl_writer_ascii.cpp:147: error: ‘strlen’ was not declared in this scope
make: *** [src/dl_writer_ascii.o] Error 1
