dxflib 3.3.4 bugs
If you are having problems with dxflib, post here. Please report bugs here.
dxflib 3.3.4 bugs
Postby joose » Fri Dec 20, 2013 6:00 pm
Hi
This document dxflib334/test/myfile.dxf is invalid, the first error is that the line break is defined as "\n" when it should be "\r\n", using a hex editor to change the 0A 0D0A and got the attached myfile.dxf:
https://www.mediafire.com/?aqwepti4wck05yn
the second error is that even so the file is invalid in all viewer drawing, so use the ODA_File_Converter_3.0.9 for errors and line 1084: "ODA Warning: Syntax error or premature end of file on line/offset 1084. OdError thrown during readFile of drawing "E:/...." : Bad Dxf sequence".
https://www.mediafire.com/?kx7sp21p19713yz
Similarly, the compiled files using dxflib334 described have the same problem. I hope you can solve these problems.
I have a DLL for Windows in bits 32-64 compiled with codeblocks 12.11 modify some lines of code to make it operational and efficient, if you're interested I can share here or in codeproject.
Regards
joose
Re: dxflib 3.3.4 bugs
Postby dgrees » Thu Apr 03, 2014 9:22 am
Hi!
i reproduced this bug.
If you try to open file myfile.dxf from package in TrueView, you see message "Expected TABLE, recieved STYLE on line 1084.".
This is because of method DL_Dxf::writeStyle. I tried to togle commented lines in code and dxf file became openable.
But this is just workaroud, what is real solution to this problem?
dgrees
Return to dxflib Troubleshooting and Problems
