LWPOLYLINE elevation value not read
If you are having problems with dxflib, post here. Please report bugs here.
Postby Aranda » Mon Mar 16, 2009 4:33 am
Hi, I also submitted a bug for this but I thought I should post here so other uses may benefit.
I was able to fix this bug by changing the DL_Dxf::addPolyline() method. The DXF specification on LWPOLYLINE (http://www.autodesk.com/techpubs/autocad/acadr14/dxf/lwpolyline_al_u05_c.htm) states that group code 38 is for elevation. DXF Lib was assuming it was the same group code as POLYLINE entity (30). Here is the modified source:
 * Adds a polyline entity that was read from the file via the creation interface.
void DL_Dxf::addPolyline(DL_CreationInterface* creationInterface) {
    if (currentEntity==DL_ENTITY_POLYLINE) {
      DL_PolylineData pd(maxVertices, toInt(values[71], 0), toInt(values[72], 0), toInt(values[70], 0), toReal(values[30]));
      creationInterface->addPolyline(pd);
   } else if (currentEntity==DL_ENTITY_LWPOLYLINE) {
      DL_PolylineData pd(maxVertices, toInt(values[71], 0), toInt(values[72], 0), toInt(values[70], 0), toReal(values[38]));
      for (int i=0; i<maxVertices; i++) {
            DL_VertexData d(vertices[i*4],
                            vertices[i*4+1],
                            vertices[i*4+2],
                            vertices[i*4+3]);
            creationInterface->addVertex(d);
      creationInterface->endEntity();
Aranda
Re: LWPOLYLINE elevation value not read
Postby p.r.thompson » Wed Apr 24, 2013 3:17 am
I also found this bug.
I noticed your patch requires modifying DL_PolylineData to include the z along with the other values and flag.
However, DXFLib already has the elevation in the extrusion field.
Therefore I think this patch is more correct and is self-contained.
diff --git a/src/dl_dxf.cpp b/src/dl_dxf.cppindex cfbab15..2afc725 100644 (file)
--- a/src/dl_dxf.cpp
+++ b/src/dl_dxf.cpp
@@ -462,10 +462,21 @@ bool DL_Dxf::processDXFGroup(DL_CreationInterface* creationInterface,
                                linetype);          // linetype
         creationInterface->setAttributes(attrib);
+        int elevationGroupCode=30;
+        if( currentEntity==DL_ENTITY_LWPOLYLINE )
+            // see lwpolyline group codes reference
+            elevationGroupCode=38;
+        else
+            // see polyline group codes reference
+            elevationGroupCode=30;
         creationInterface->setExtrusion(toReal(values[210], 0.0),
                                         toReal(values[220], 0.0),
                                         toReal(values[230], 1.0),
-                                        toReal(values[30], 0.0));
+                                        toReal(values[elevationGroupCode], 0.0));
p.r.thompson
Postby andrew » Wed Apr 24, 2013 12:22 pm
p.r.thompson: Many thanks for the patch. I will incorporate this in the next dxflib release if you don't mind.
Return to dxflib Troubleshooting and Problems
cron
