Install problem under linux
If you are having problems with vec2web, post here. Please report bugs here.
Postby edi » Wed Apr 04, 2007 5:50 pm
I have just downloaded vec2web, set QTDIR and started the build script. However, when building libqcad I got:
../include/rs_math.h:90: warning: unused parameter ‘ok’
engine/rs_entity.cpp: In function ‘std::ostream& operator<<(std::ostream&, RS_Entity&)’:
engine/rs_entity.cpp:864: error: cast from ‘RS_Layer*’ to ‘int’ loses precisionmake[2]: *** [obj/rs_entity.o] Error 1
What is wrong? I have Ubuntu 6.06 with qt3.3 installed.
edi
Re: Install problem under linux
Postby andrew » Fri May 04, 2007 9:36 am
You can safely comment that part out, it is only used for debugging.
edi wrote:Hi,
Return to vec2web Troubleshooting and Problems
