Questions about strings for QCad V2.2
Posted: Wed Mar 19, 2008 10:13 am
- File qcad_xx.ts
'Library Browser': Can you browse one or more libraries?
- File qcadactions_xx.ts
'Duplicate Floor': Is 'duplicate' used as a verb in this string? What does 'floor' mean in this context? Is it an equivalent for 'Plane'?
'Specify first break point on a polyline': Could you please explain what a 'break point' is?
'Choose first edge': This is a string that relates to windows. Does 'edge' refer to a line or line segment that is the intersection of two plane faces (as of a pyramid) or of two planes or is it an equivalent for 'border'?
- qcadlib_xx.ts
'Extension Point 1|X': Is this an extension point or a point on an extension line?
'Def. Point|Y': Does 'Def.' stand for 'Definition' or 'Define'?
'Extension|X1': Does extension refer to extension lines?
- qcadguiqt_xx.ts
'Check to...' (appears a number of times in this file): Does it mean to put a check mark to select an option or to make sure?
'Architectural Tick': Does 'tick' refer to 'a check mark'? Can you point to the image of such an arrow type on the Web? Thanks.
'Window preview:' Is this a window for previewing or a command name for previewing the contents of a given window?
Many thanks in advance for your quick reply.
Eric
- qcadlib_xx.ts
- qcadguiqt_xx.ts
Eric
