Feature or Bug?
Posted: Wed Sep 08, 2010 10:16 am
If I insert a object from the Library Browser that contains layers, when inserted in the drawing the layers show up in the Layer List but you can not turn visablity of the layer on or off. If I select Edit Undo followed by Redo the block breaks into the correct layers allowing the visablity of each layer to be turned on or off and you can edit each layer or remove the entities. I can't make up my mind as to this being a feature or a bug? Windows XP Pro 2.2.2.0 Pro.
