Setting file export path
Re: Setting file export path
Postby andrew » Fri Apr 27, 2012 5:41 pm
I've just seen that the PolylineEquidistant class is not yet suitable for non-interactive use. The changes required are relatively minor though. If I have time I will upload a new version for file PolylineEquidistant.js and small example here in the coming days.
ash120
Postby ash120 » Tue May 01, 2012 5:02 am
Thanks for that Andrew I would be great if class that would work as really be useful...,
I'm Finding Qcad scripting really powerful and easy once you get the feel for how the class structure works. Ecmascript is a really good choice for a scripting language too. :)
Postby andrew » Fri May 11, 2012 12:34 am
I've adjusted the equidistant function, so it can be called from other scripts.
The parameters are:
polylineEntity: RPolylineEntity: Base polyline entity.
number: Number of equidistans to create.
distance: Distance between base and first equidistant.
side: RS.RightHand or RS.LeftHand
useArcsAtCorners: true: round corners / false: sharp corners.
Replaces scripts/Draw/Polyline/PolylineEquidistant.js
(20.35 KiB) Downloaded 327 times
Return to “QCAD 3 Developers and Contributors”
Users browsing this forum: No registered users and 5 guests
