Re: Movement animation - update problem [SOLVED]
Postby mariosboarina » Thu Nov 29, 2012 5:15 pm
I'm testing QCad/ECMAScript in order to do movement 2D animations.
I ran a little test script: apply a little step (1,1) movement on a preselected block, inside a for cycle, with a sleep between every step.
I get no errors, but I can't see intermediate positions: only the last one (when its time comes, at last of the animation); so I see no animation.
Also: at the end of actions I cannot select the moved block unless I do it with a selection window which includes also the original position of the block (so it looks).
If I run QCad with debugger enabled the problem doesn't appear.
There might be some update problems with document or rappresentation data of entities.
I tried all update/repaint/regenerate commands in the document interface with no effect.
I run QCad-trial 3.0 on a Windows 7 SP1 (64bit) machine.
This is the testing code:
   var document = this.getDocument();
   var storage = document.getStorage();
    var di = this.getDocumentInterface();
    var ids = document.querySelectedEntities();
    blockRef = document.queryEntity(ids[0]);
   blockRef.setSelected(false);
   var newPosition = new RVector(1,1);
   for (i=0; i<30; i++) {
      var op = new RModifyObjectsOperation();
      blockRef.move(newPosition);
      op.addObject(blockRef);
      di.applyOperation(op);
      blockRef.update();
      sleep(50);
      di.updateAllEntities
      document.updateAllEntities();
      di.regenerateScenes(ids[0],true);
      di.regenerateViews(true);
      di.repaintViews();
    this.terminate
Thanks for help
Ciao
Mario
mariosboarina
Postby mariosboarina » Tue Dec 04, 2012 11:47 am
some updating on the problem:
I added the line
document.rebuildSpatialIndex();
so I don't have the selection problem anymore,
but still I can't solve the main problem: I can't see the animation running but only the last step.
Ciao
Mario
mariosboarina
Postby mariosboarina » Wed Dec 12, 2012 7:22 pm
Solved, at last: just have to process events on every step.
before the cycle:
var el = new QEventLoop()
inside the cycle:
el.processEvents();
Ciao
mariosboarina
Postby andrew » Wed Dec 12, 2012 7:44 pm
Note that processing events inside a script is not recommended. It allows the user to 'do something' while your script is running (e.g. close the document, open a new file, etc.). This can have very undesirable effects (crashes).
You might be able to simply force an immediate repaint instead:
var view = EAction.getGraphicsView();
// loop
    view.repaintNow();
// end of loop
Postby mariosboarina » Thu Dec 20, 2012 3:21 pm
Ok, thank you for reply,
I'll try it soon with repaintNow()
mariosboarina
Postby mariosboarina » Thu Dec 27, 2012 2:16 pm
Ok. Tested. It works perfectly.
Thank you again.
mariosboarina
Return to QCAD 3 Developers and Contributors
