run a modified script
Postby Surendranath » Thu Jan 10, 2013 10:56 am
How do I run a script after modifying it?
Should I restart qcad or is there some reload option from the command line?
I am a beginner and I need to modify the code if does not give the right result.
Restarting qcad each time seems heavy.
Surendranath
Re: run a modified script
Postby andrew » Thu Jan 10, 2013 11:05 am
Try these command line switches for development:
-always-load-scripts             Forces reloading of scripts when they are used.
                                 This is mainly useful during script development,
                                 to apply changes without restarting QCAD.
-enable-script-debugger          Enables the script debugger.
-rescan                          Rescan scripts folder for new plugins
See also ./qcad -h
Note that -enable-script-debugger can also lead to crashes or unpredictable behavior, but it can be helpful for debugging. The debugger comes up if there's an error or if it meet a debugger statement:
debugger;
Postby Surendranath » Thu Jan 10, 2013 2:33 pm
I tried the command line options and they did not work for me.
This is my scenario. I have the script file open in a text editor.
I run this script from QCAD. it works.
I modify a line in the script file and call it again. It is the old file that is being executed.
Surendranath
Postby andrew » Thu Jan 10, 2013 2:57 pm
Return to QCAD 3 Developers and Contributors
Users browsing this forum: Yahoo [Bot] and 1 guest
cron
