ok button
ok button
Postby Surendranath » Sat Jan 26, 2013 1:16 am
Could u please post a piece of code on the use of a push button to close a dialog.
I have a dialog with some radiobuttons, a combobox and a pushbutton. When the pushbutton is clicked I want the dialog closed and the values of the selected item and the state of the radio buttons returned.
Surendranath
Re: ok button
Postby andrew » Sat Jan 26, 2013 8:44 am
A simple example for this is the BitmapExport Dialog in:
scripts/File/BitmapExport/BitmapExport.js
and
scripts/File/BitmapExport/BitmapExportDialog.ui
Creating the dialog:
var dialog = WidgetFactory.createDialog(BitmapExport.includeBasePath, "BitmapExportDialog.ui", appWin);
Getting a pointer to a GUI element:
var widthEdit = dialog.findChild("Width");
Running the dialog:
if (!dialog.exec()) {
    // dialog cancelled
Getting the user input from the dialog:
widthEdit.getValue();
Re: ok button
Postby Surendranath » Sat Jan 26, 2013 3:36 pm
Thanks. That did the job.
I am able to create a dialog using qcreator and use it my program.
one thing though I could not get the degree symbol in the text for the radiobutton using unicode
I was actually trying to create a dialog programmatically.
Please check the following code. (I am just curious to make this work)
What should I do to get the chosen index from combo box and the state of the radio button and close the dialog when the push button is clicked.
function InsertBlockDialog() {
    this.choice = 0;
    this.angle = 0;
    this.blocks = new Array("Cell", "Capacitor", "Inductor", "Resistor", "AC", "Instr", "Terminal");
     var dialog = new QDialog(RMainWindowQt.getMainWindow());
    var vbl = new QVBoxLayout();
    var RBW = new QWidget();
    var RBLO = new QHBoxLayout();
    var RBWL = new QLabel("Value :");
    RBLO.addWidget(RBWL, 0, 0);
    RBW.setLayout(RBLO);
    vbl.addWidget(RBW, 0, 0);
    var comboBox = new QComboBox();
    for (var i = this.blocks.length - 1; i >= 0; --i) {
         comboBox.insertItem(0, this.blocks[i]);
    var pb = new QPushButton("Done", dialog);
    var rb1 = new QRadioButton("0\u00B0");
    rb1.checked = true;
    var rb2 = new QRadioButton( "90\u00B0");
    var rb3 = new QRadioButton("180\u00B0");
    var rb4 = new QRadioButton("270\u00B0");
    var RBL = new QLabel("Angle :");
    RBLO.addWidget(RBL, 0, 0);
    RBLO.addWidget(rb1, 0, 0);
    RBLO.addWidget(rb2, 0, 0);
    RBLO.addWidget(rb3, 0, 0);
    RBLO.addWidget(rb4, 0, 0);
    var dialogLayout = new QVBoxLayout();
    dialogLayout.addWidget(comboBox, 0, 0)
    dialogLayout.addWidget(RBW, 0, 0);
    dialogLayout.addWidget(pb, 0, 0);
    dialog.setLayout(dialogLayout);
    dialog.setWindowTitle("::: Block  :::");
    pb.clicked.connect(function () {
        this.choice = comboBox.currentIndex;
        if (rb1.checked)
            this.angle = 0;
        else if (rb2.checked)
            this.angle = 90;
        else if (rb3.checked)
            this.angle = 180;
        else if (rb4.checked)
            this.angle = 270;
    dialog.exec();
Surendranath
