Changing entity properties
Postby andrew » Thu Aug 08, 2013 1:52 pm
From a QCAD developer:
How can I set / change properties and custom properties of existing entities?
Re: Changing entity properties
Postby andrew » Thu Aug 08, 2013 2:02 pm
You can change properties through an operation in the same way as you would change the geometry of an entity.
Note that operations live on a higher level than transactions. An operation triggers a transaction underneath and in addition keeps the views up to date. Operations can also be previewed. Whenever a document has views attached to it, use operations. If a document is being modified without views, a transaction may be used instead.
// create new operation:
RModifyObjectsOperation* op = new RModifyObjectsOperation();
// fetch existing entity:
QSharedPointer<REntity> entity = document->queryEntity(entityId);
// TODO: check if entity is NULL
// change entity:
// set / change custom property:
entity->setProperty(RPropertyTypeId("MyProperty"), 37.5);
// set fixed property:
entity->setProperty(REntity::PropertyColor, RColor("blue"));
// which is the same as:
entity->setColor(RColor("blue"));
// set layer ID:
entity->setLayerId(...);
// add modified entity to operation:
op->addObject(entity);
// apply operation to document (trigger transaction) and update views, etc.
// document interface takes ownership of the operation (deletes it when done)
documentInterface->applyOperation(op);
The same in ECMAScript:
var op = new RModifyObjectsOperation();
var entity = document.queryEntity(entityId);
// TODO: check if entity is undefined
// change entity:
entity.setProperty(new RPropertyTypeId("MyProperty"), 37.5);
entity.setProperty(REntity.PropertyColor, new RColor("blue"));
entity.setColor(new RColor("blue"));
// set layer ID:
entity.setLayerId(...);
op.addObject(entity);
// apply operation to document (trigger transaction) and update views, etc:
documentInterface.applyOperation(op);
