RAction vs. ROperation
Postby andrew » Mon Nov 18, 2013 10:41 am
From a QCAD user:
In browsing the QCAD source, I've come across a little bit of confusion: I see RAction and ROperation, but I'm a little bit confused at the difference between them, and how they're related. Could you clarify?
Re: RAction vs. ROperation
Postby andrew » Mon Nov 18, 2013 10:47 am
RAction classes handle user interaction with a document. An action reacts to mouse clicks, coordinates that are being entered, etc.
Example for RAction implementations: File - Open, Zoom in, Draw line from two points and any other QCAD tool.
Actions are the 'glue' between the user inputs and the QCAD application.
ROperation classes encapsulate a modification that can be applied to a document.
Such an operation might add objects (entities, layers, blocks, ...), delete objects or modify objects.
Operations are a low level concept and would also exist in an application without user interface.
Postby galed » Mon Nov 25, 2013 7:07 pm
What about RGuiActions? They seem kind of redundant with RActions
How are ROperations rolled into the undo framework provided by the transaction stack?
galed
Postby andrew » Tue Nov 26, 2013 10:27 am
galed wrote:What about RGuiActions? They seem kind of redundant with RActions
A GUI action (RGuiAction) represents an action in the user interface. A GUI action is typically visualized by a menu and optionally a tool button. RGuiActions can also be triggered through command input. RGuiAction is derived from QAction and serves the same purpose.
ROperations typically trigger transactions (RTransaction) on a lower level. Transactions are undoable.
Return to QCAD 3 Developers and Contributors
