QCad based app and Qcad itself load a dxf file differently!
s4eed
Postby s4eed » Sun Nov 24, 2013 6:52 pm
Hi dear users specially dear Andrew.
I tired to create new app based on QCad using this question (http://www.qcad.org/rsforum/viewtopic.php?f=30&t=2675). Every thing is OK and I changed some of scripts and added some new scripts to my own app.some of them was deleted.
But now when I load a dxf file in my app and in QCad itself(without any changes) results are different !
Here is the result from QCad itself(loaded normally) :
And here is the result of my own app(not normal):
I also attached my dxf file.
I deleted qcadcamscripts.dll qcaddwg.dll qcadproscripts.dll from plugins folder.
Cars Pickups and Vans 3.dxf
(827.72 KiB) Downloaded 166 times
Re: QCad based app and Qcad itself load a dxf file different
Postby andrew » Sun Nov 24, 2013 10:39 pm
Thanks for the file. This appears to be a bug related to DXF import when using the free QCAD version without the Teigha plugin (qcaddwg.dll).
Bug report:
http://www.qcad.org/bugtracker/index.ph ... ask_id=976
You might want to re-enable DXF import through Teigha for now (copy qcaddwg.dll from the downloaded package back to to the plugins folder or reinstall the QCAD trial version).
s4eed
Postby s4eed » Mon Nov 25, 2013 11:56 am
You're welcome. I'm happy for my first contribution to this great software.
Return to “QCAD 3 Developers and Contributors”
