Clear undo stack
Clear undo stack
Postby sramp » Tue Feb 11, 2014 5:27 pm
I'm building a custom tool and to help the user the tool creates some construction lines ( RLineEntity ). These lines will be deleted at the end by the script.
The tool works as expected, but I have some problems with the undo command, since I got a crash.
I suppose that references of construction lines are still in the undo stack.
Is there a way to reset the undo stack in a safe state?
sramp
sramp
Re: Clear undo stack
Postby andrew » Wed Feb 12, 2014 9:38 am
If you create and delete everything in operations (RAddObjectsOperation, RDeleteObjectsOperation, ...), this should never be an issue.
Perhaps, you can post the relevant part of your code?
Postby sramp » Thu Feb 13, 2014 10:26 am
There is an error in my logic and this is the real cause of the problem.
I create some lines ( undoable true )
I delete the lines ( undoable false )
If I set as undoable every operation everything works fine.
I could set not undoable the lines creation too, but this makes the tools less usable during the lines creation.
sramp
Postby andrew » Thu Feb 13, 2014 10:49 am
Yes, undoable should actually always be true unless a file is being loaded.
Return to QCAD 3 Developers and Contributors
