[SOLVED] RRay bug or misunderstanding?
smf
Post by smf » Tue Dec 16, 2014 1:56 pm
I tried to intersect two RRay objects, but the result is "not as expected". Given to already existing lines, I created two RRays thereof and intersect them:
this.rayAlign = new RRay(this.lineAlign.getStartPoint(), this.lineAlign.getEndPoint());
this.rayDest = new RRay(this.lineDest.getStartPoint(), this.lineDest.getEndPoint());
var inters = this.rayAlign.getIntersectionPoints(this.rayDest);
The code above does not give the valid intersection points (if startet with script debugger on, there are several unexpected debug-messages). Using RLines instead of RRays like the following variant delivers the correct intersection points, if scaling is big enough to have lines intersected:
this.rayAlign = new RLine(this.lineAlign.getStartPoint(), this.lineAlign.getEndPoint());
this.rayDest = new RLine(this.lineDest.getStartPoint(), this.lineDest.getEndPoint());
this.rayAlign.scale(this.scaling, this.lineAlign.getMiddlePoints()[0]);
this.rayDest.scale(this.scaling, this.lineDest.getMiddlePoints()[0]);
I don't know wheter if this is a bug or if I missed something using RRays - aren't those just RLines with infinitive length?
Re: RRay bug or misunderstanding?
Post by andrew » Tue Dec 16, 2014 3:04 pm
I'd have to see the actual coordinates to see if this is a bug.
I like to test such situations in simple test scripts like this:
File test.js:
var r1 = new RRay(new RVector(10,10), new RVector(1,0));
var r2 = new RRay(new RVector(50,0), new RVector(0,1));
var inters = r1.getIntersectionPoints(r2);
qDebug(inters);
Such a script can be run directly, using QCAD as interpreter only:
./qcad -autostart test.js
Output:
Debug:    RVector(50, 10, 0)
smf
Post by smf » Tue Dec 16, 2014 4:46 pm
Thank you for the fast response and the hint about qDebug. My first mistake was a misunderstanding in the RRay constructor: the second parameter is "direction" and not "end point". e_surprised So RRay is with respect to the constructor not an replacement for infinite RLine. I should have rtfm better... :oops: Sorry.
Anyhow, the intersection is still not what I expect. My testscript is:
//globals
var scaling=new RVector(1000, 1000);
//setting up the "clicked" lines
var d=new RLine(new RVector(812.542, 546.024, 0), new RVector(828.48, 541.753, 0));
var a=new RLine(new RVector(179.749, 96.7045, 0), new RVector(184.019, 80.7667, 0));
//getting intersection of orthogonal rays with RLine
var lrd=new RLine(d.getStartPoint(), d.getEndPoint());
lrd.rotate(Math.PI / 2, d.getMiddlePoints()[0]);
lrd.scale(scaling, d.getMiddlePoints()[0]);
var lra=new RLine(a.getStartPoint(), a.getEndPoint());
lra.rotate(Math.PI / 2, a.getMiddlePoints()[0]);
lra.scale(scaling, a.getMiddlePoints()[0]);
var ilda = lrd.getIntersectionPoints(lra);
qDebug(ilda);
//getting intersection of orthogonal rays with RRay
var rrd=new RRay(d.getStartPoint(), new RVector(d.getEndPoint().getX()-d.getStartPoint().getX(), d.getEndPoint().getY()-d.getStartPoint().getY()));
rrd.rotate(Math.PI / 2, d.getMiddlePoints()[0]);
var rra=new RRay(a.getStartPoint(), new RVector(a.getEndPoint().getX()-a.getStartPoint().getX(), a.getEndPoint().getY()-a.getStartPoint().getY()));
rra.rotate(Math.PI / 2, a.getMiddlePoints()[0]);
var irda = rrd.getIntersectionPoints(rra);
qDebug(irda);
the output is (second line is empty after "Debug"):
Debug:    RVector(738.504, 237.863, 0)
Debug:
It seems as if I'm doing something more the wrong way. :(
Post by andrew » Tue Dec 16, 2014 4:56 pm
Bit complicated.. ;)
Can you output the rays used for the calculation:
qDebug("first ray:", rrd);
qDebug("second ray:", rra);
qDebug("result:", irda);
smf
Post by smf » Tue Dec 16, 2014 5:49 pm
This gives me:
Debug:    first ray: RRay(RShape(address: "0x1795a20"), basePoint: RVector(818.375, 535.92, 0), directionVector: RVector(4.271, 15.938, 0))
Debug:    second ray: RRay(RShape(address: "0x17962f0"), basePoint: RVector(173.915, 86.6006, 0), directionVector: RVector(15.9378, 4.27, 0))
Debug:    result:
I'm using QCad 3.6.0 Pro under XUbuntu 14.04 LTS.
Post by andrew » Tue Dec 16, 2014 6:23 pm
I'm not at my desktop now, but these rays don't look like they intersect.
Perhaps enter these rays into a QCAD drawing..
smf
Post by smf » Tue Dec 16, 2014 6:59 pm
Thank you for the response. What makes me wonder is: the RLines are intersecting correctly, so I would assume that RRays would do at the same position. Perhaps I'm still using RRays wrong? At the moment the workaround with scaled RLines is fine - so no hurry. :)
Post by andrew » Tue Dec 16, 2014 8:43 pm
So I've entered these rays into QCAD for you:
Screen Shot 2014-12-16 at 20.41.32.png (20.01 KiB) Viewed 9351 times
There is no intersection point, which appears to be correct.
smf
Post by smf » Tue Dec 16, 2014 8:58 pm
Thank you very much - so this prooves that I had another misunderstanding: I thought of a ray being infinite in both directions. :(
Post by andrew » Tue Dec 16, 2014 9:29 pm
smf wrote:Thank you very much - so this prooves that I had another misunderstanding: I thought of a ray being infinite in both directions. :(
No. That would be an XLine (RXLine).
smf
Re: [SOLVED] RRay bug or misunderstanding?
Post by smf » Tue Dec 16, 2014 10:11 pm
Thanks again. :) With RXLine and the correct constructor usage the result for
//globals
qDebug("scaled line:", ilda);
//getting intersection of orthogonal xlines with EXLine
var rrd=new RXLine(d.getStartPoint(), new RVector(d.getEndPoint().getX()-d.getStartPoint().getX(), d.getEndPoint().getY()-d.getStartPoint().getY()));
var rra=new RXLine(a.getStartPoint(), new RVector(a.getEndPoint().getX()-a.getStartPoint().getX(), a.getEndPoint().getY()-a.getStartPoint().getY()));
qDebug("plain xline:", irda);
is :D
Debug:    scaled line: RVector(738.504, 237.863, 0)
Debug:    plain xline: RVector(738.504, 237.863, 0)
