Best fit development environment for c++
mink
Post by mink » Thu Jan 29, 2015 9:54 am
I am struggling to set up a development environment for QCad development in C++.
Until now, without success. I downloaded Qt everywhere; but fail to configure it on a Windows 7 machine. Is there any cookbook or documentation with step by step instructions? (NB: the target system is definitely Windows, however I would not care if the development environment would be linux ...)
Any ideas?
Ulrich
PS: I want to thank for the answers I got so far! I adore your speed and technical excelence!
Re: Best fit development environment for c++
Post by andrew » Thu Jan 29, 2015 10:04 am
Brief compilation instructions for Windows are available at:
http://www.qcad.org/en/component/conten ... es#windows
I'm using cygwin as shell and jom instead of nmake under Windows, but the Windows command line and nmake will also work.
mink
Post by mink » Thu Jan 29, 2015 4:44 pm
Thanks for your answer. It help to investigate into the correct direction: to set the environment variables (a little bit more as the vsvars32.bat thing...). But right now, I have nmake building Qt in my cygwin window (at least a unix-like environment! great!), and it seems to be work okay!
Ulrich
