build qcad with Qt built for debug
mink
Post by mink » Fri Jan 30, 2015 8:39 am
Hi again,
after having resolved some obstacles between Windows and Unix / cygwin, and having all evironment set up for msvc2010, my build of QT in debug-version went ok. Trying to build QCad (from 4.7.6-zip) led to following problem:
qmake -r stops because a plugin plugins/designer/qwebview.dll is missing. As I built Qt for debug, I only have a qwebviewd.dll ....
Is this a little mistake in the .pro-Files?
As a workaround, i am building Qt now with -debug-and-release. Think this will create the missing release-plugin.
Ulrich
Re: build qcad with Qt built for debug
Post by andrew » Fri Jan 30, 2015 10:29 am
There's something special about qwebview... IMHO, Qt should take care of the 'd' though.
Personally, I've never linked against Qt in debug mode under Windows as I only do Windows releases on Windows and prefer to develop on other platforms. So it's perfectly possible that something would have to be adjusted to make this work.
