RActionAdapter::escapeEvent not called on right mouse button
mink
Post by mink » Tue Apr 14, 2015 12:53 pm
documentation of RActionAdapter states:
virtual void escapeEvent ()
Escape events are triggered if the user clicks the right mouse button or hits the Escape key.
implementing escapeEvent in an action works fine - it is called when user hits escape key.
However, my function is not called when user clicks the right mouse button....
observed in 3.8.1 win and linux
also in 3.9.1 win (linux version still comiling QCad sources ...)
Any hints?
Thanks and regards,
Ulrich
Re: RActionAdapter::escapeEvent not called on right mouse bu
Post by andrew » Tue Apr 14, 2015 3:26 pm
This functionality is actually implemented in EAction:
EAction.prototype.mouseReleaseEvent = function(event) {
    if (event.button() === Qt.RightButton) {
        this.escapeEvent();
If your action is implemented in ECMAScript and derived from EAction, escapeEvent should be triggered, otherwise you can provide your own similar implementation of mouseReleaseEvent.
mink
Post by mink » Wed Apr 15, 2015 6:40 am
Hi Andrew,
thanks a lot ! Implementing myAction::mouseReleaseEvent did the trick.
Ulrich
