spline 3 degree limit ? Bug ?
vroemm
Post by vroemm » Sun Feb 07, 2016 6:02 pm
Hi..
I hope this is the right place in the qcad forum to make this contribution.
If not, please point me to the right place.
I used a spline in qcad 3.12.6 with 7 points.
In the properties editor -> degree i could choose between 1 to 6 degree.
The drawing showed a difference between selecting 1, 2 .. 6 degree.
I choose 5.
Then i saved the drawing, closed the drawing, and opened the drawing again.
The something strange happened.
The DEGREE of the spline was changed from 5 to 3 .
The drawing showed the result of 3 degree.
The setting 5 degree was lost.
Then i downloaded the source code to see what happened.
I am a low level hobby programmer, with no experience in programming QCAD.
So it could be i did something stupid ;-))
In qcad-3.12.6.0/src/io/dxf/RDxfImporter.cpp
In:
void RDxfImporter::addSpline(const DL_SplineData& data) {
i changed the line :
if (data.degree<=1 || data.degree>3)
To :
if (data.degree<=1 || data.degree>= data.nControl )
Now it looks like qcad spline can remember the 5 degree.
It seems to work fine.
Is this a correct code change ?
I do not understand why spline first offered one less degree then then number of points.
Is this somehow needed ?
I toke data.nControl to limit the degrees, is this right or wrong ?
Does this solution break some international dxf definition or something ?
What do i know :-)
Vroemm.
Re: spline 3 degree limit ? Bug ?
Post by andrew » Mon Feb 08, 2016 10:36 am
Thanks. Yes, that check is obsolete. I think it's better not to check the degree at that point at all. The spline will simply fail to render at a later stage if it is invalid.
Commit:
https://github.com/qcad/qcad/commit/30e ... b0aa64322a
A spline by definition always needs at least degree+1 control points.
vroemm
Post by vroemm » Tue Feb 09, 2016 3:32 pm
Thanks..
It feels good to contribute something to QCAD.
A smile on my face and a warm feeling.. :-)
Vroemm.
