When i import dxf file ,there a question abut messy code
skyboy
Post by skyboy » Tue Apr 19, 2016 6:58 am
When i import dxf file ,there a question abut messy code,the file has chinese word ,how to solve this question ,thank you
Re: When i import dxf file ,there a question abut messy code
Post by andrew » Tue Apr 19, 2016 7:54 am
Thanks for your report.
- indicate the operating system you are using and the version thereof
- indicate the exact version of QCAD you are using (see Help > About or QCAD > About QCAD)
- indicate the QCAD Edition you are using (QCAD Professional, QCAD Demo-Version, QCAD Community Edition)
- attach original drawing files (DXF, DWG, ...) if appropriate
- include screenshots if appropriate
- if there is an error message, indicate the exact message
Please be as specific as possible in describing your problem, so we can help you efficiently.
