return code
pmakowski
return code
Post by pmakowski » Tue Aug 16, 2016 10:54 am
we have a plugin that we run in command line mode
qcad.exe" -no-gui -allow-multiple-instances -autostart "C:\Program Files\QCAD\/scripts/Tools/VisionOnly.js"
we would like to get a return code in case of success or failure, because we launch that with a dos bat file, we tried this way without success :
 int = function main() {
    if (testArgument(args, "-h", "-help")) {
        printHelp();
        return 0;
    if (args.length < 3) {
        print("No input file given. Try -h for help.");
        return 595;
    var cadFileName = args[args.length - 1];
    if (isNull(cadFileName) || cadFileName.indexOf("-") === 0) {
        print("No input file. Try -h for help.");
        return 2;
return main();
Any clue ?
Re: return code
Post by andrew » Tue Aug 16, 2016 11:39 am
The return code of qcad.exe is the return code of main implemented in C++ which is 0 if there was no error in the script or 1 if there are uncaught exceptions.
A potential workaround might be to exit the application with:
QCoreApplication.exit(returnCode);
pmakowski
[Solved]Re: return code
Post by pmakowski » Wed Aug 17, 2016 8:14 am
Thanks, it is what we need.
