when undo, how can get type of entity?
- Active Member
when an entity is selected, its' type can be acquired easily. However, when an entity is undid or redid(in the 'Edit' menu), how to get its' type? Thanks!
Re: when undo, how can get type of entity?
The undone status is just a flag of the object (entity in this case). You can get it the same way as for a regular entity (getType or through dynamic_cast).
- Active Member
if a block is deleted, then undo, can the name of block be got? how? thanks!
If you want to be notified the deletion of a block, you'd best implement an RTransactionListener. You can find an example at: https://github.com/qcad/qcad/blob/maste ... istener.js
Transaction listeners are notified whenever 'something changes' (object added, object modified, object deleted), also during undo / redo.
