[solved] reopen the dxf file after it has been modified externally
Nick1974
Post by Nick1974 » Wed Oct 11, 2017 2:05 pm
Hello.
How I can say to qcad so it reopens the dxf file after it has been modified externally?
I draw from ECMAScript:
1. Open qcad
2. Edit myscript.js and run from editor
qcad -allow-multiple-instances -autostart myscript.js && qcad /tmp/myscript.dxf
3 View result in qcad
4. Switch to qcad
5. Close documet /tmp/myscript.dxf (Ctrl-W)
6. Switch to the editor
7. Goto 2
If qcad reopens the dxf file after it has been modified externally, I will be able to stay in the editor:
1. Open qcad
4. Goto 2
Re: reopen the dxf file after it has been modified externally
Post by andrew » Wed Oct 11, 2017 2:11 pm
You could trigger a File > Revert after running your script:
1. Launch QCAD (and keep it running):
2. Regenerate file and trigger File > Revert when done:
qcad -allow-multiple-instances -autostart myscript.js && qcad -exec scripts/Pro/File/RevertFile/RevertFile.js
A warning dialog will be shown in QCAD if the file has been modified in QCAD.
Note that launching QCAD if it is already running will pass the arguments to the running instance. This way you can open additional files from the command line or trigger commands as shown above.
Nick1974
Post by Nick1974 » Mon Oct 16, 2017 12:01 pm
Many thanks!
