How to catch command from command line in a script
dzenita
Post by dzenita » Mon Nov 27, 2017 3:54 pm
Hi all,
QCad has support for drawing lines, circles via command line like this :
2017-11-27 15_39_08-Untitled 1 _ - QCAD.png (13.99 KiB) Viewed 2672 times
but how can we draw line using one row, one step, using command like this --> line (10;10 , 20;20)
And how to catch command from command line in a script ?
I have some custom functions which I should call from command line with parameters in one row, is that possible. I am using QCad 3.19.1 version.
Thanks,
Dzenita
Re: How to catch command from command line in a script
Post by andrew » Mon Nov 27, 2017 4:48 pm
You might want to use the script shell for this:
View > Toolbars > Script Shell
addLine(10,10, 20,20);
for (i=0; i<10; i++) { addLine(10,i*10, 20,i*10); }
See also:
https://www.qcad.org/doc/qcad/latest/de ... imple.html
dzenita
Post by dzenita » Wed Nov 29, 2017 1:19 pm
Great, thanks a lot Andrew.
Best regards,
Dzenita
