Custom properties persistence
narotu
Post by narotu » Tue Jan 09, 2018 5:04 pm
Please I have a question, are custom properties persistent ?
Through the post : https://qcad.org/rsforum/viewtopic.php?t=2544, it wroted : "XData support is experimental and therefore disabled by default. Custom properties that are attached to an entity are persistent (that means they are saved and can be read from DXF / DWG files).
But I use qcad 3.19 and after saving and reopening the document I don't find my custom properties attached to my entity, even with direct search in dxf file I don't find my custom properties.
(I work with enabling xdata, and I tried with qcad free and qcad pro).
Thanks in advance for your explanation.
Best regards
narotu
Re: Custom properties persistence
Post by andrew » Wed Jan 10, 2018 10:13 am
Custom properties are only supported in QCAD Professional. And only when saving through one of the Teigha based DXF/DWG formats (default).
You can test this using the property editor. Simply select an entity and add custom properties in the property editor:
Screen Shot 2018-01-10 at 09.12.11.png (87.27 KiB) Viewed 1644 times
